Si ca peut aider
Plus précisément ca donne ça :
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CB HW: 3C0 907 044 CB
Component: ClimatronicPQ46 122 0707
Revision: 00122021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 63CEADD29D0FAE04
1 Fault Found
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 5
Fault Frequency: 3
Reset counter: 40
Mileage: 79674 km
Time Indication: 0
Date: 2011.09.29
Time: 18:52:50
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007262541
Coding: E5888F0700041A00470A00000F00000000095D435C000100000000000000
Shop #: WSC 05124 000 00000
VCID: 71E2D79A57F30C94
Part No: 3C1 955 419 A
Component: Wischer 180507 003 0205
Coding: 00046997
Shop #: WSC 05124
Part No: 1K0 955 559 AB
Component: RLS 220607 020 0105
Coding: 00208933
Shop #: WSC 05124
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 79674 km
Time Indication: 0
Date: 2011.09.29
Time: 18:53:00
Freeze Frame:
ON
Voltage: 12.35 V
ON
ON
OFF
OFF
OFF
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3690P114191003
Coding: FD80FF0E02020200F100
VCID: 2F6611E281475A64
1 Fault Found
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Mileage: 79674 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.136 H08 1901
Shop #: WSC 02069 000 90108
VCID: 356A238A631B60B4
1 Fault Found
00750 - Warning Lamp
013 - Check DTC Memory - Intermittent
Freeze Frame:
Mileage: 79660 km
Temperature: 39.0°C
Voltage: 12.50 V
Voltage: 12.30 V
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: KSG PQ46 ELV 042 0472
Revision: 00042000 Serial number: VWZCZ000000000
Coding: 00900A00D1030E76300494157008CF0B607800
Shop #: WSC 05311 000 00000
VCID: 39722FBA4F0384D4
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 79674 km
Time Indication: 0
Date: 2011.09.29
Time: 18:52:45
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
Component: Parkhilfe 8-Kan 004 0013
Revision: 00004000 Serial number: 90630716907805
Coding: 0001024
Shop #: WSC 05311 000 08193
VCID: 2952FFFABFA33454
1 Fault Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Mileage: 79674 km
Time Indication: 0
Date: 2011.09.29
Time: 18:52:50
