Sujet : Décodeur codes options VAG
Un petit outil sympa pour décoder les codes options présents sur l'étiquette de nos voitures
Re : Décodeur codes options VAG
[bravo]
Depuis le temps que je cherchais ça merci 8)
Passat 3BG Highline 2.8L V6 193cv
A tester de toute urgence ...
Merci callahan1
Bonne trouvaille Inspecteur. [dac]
Sympa ce logiciel !!!
B0A = Component parts set without country-specific design requirement
CA5 = Alloy wheels 7.5J x 17
G0K = 6-speed manual transmission
HK0 = Tires 235/45 R17 97W x1
J0N = Battery 330 A (61 Ah)
D91 = 4-cyl. turbo diesel engine 2.0 l/103 kW (4V) TDI common rail; Base engine: TG3/ TJ3/TU3/TU4/TL4/TP4/TM3/TW3/TR4/TS1/TN5
1AT = Electronic stabilization program (ESP)
1G3 = Alloy spare wheel with original equipment tires
2ZB = Leather multi-function steering wheel
5RQ = Right exterior mirror: convex
5SL = Left exterior mirror: aspherical
TG3 = 4-cylinder diesel engine 2.0 L unit 03L.A
3S1 = Bright roof rails
8TC = Rear fog light for driving on the right
QG1 = Service interval prolongation
8AE = Radio "RCD310 MP3"
8GV = Alternator 180 A
8RM = 8 speakers (passive)
1ZM = Disc brakes, front (Geomet D)
L02 = Suspension range 02 installation control only, no requirement forecast
0YE = Weight range 5 installation control only, no requirement forecast
G07 = Front shock absorption
7MG = Emission standard EU5
Ca y est j'ai été chercher ma Passat et hop un coup de décodeur :
CP4 = Alloy wheels 7.5J x 17
G1A = 6-speed automatic transmission
H01 = Tires 235/45 R 17 94W (polymer coating)
J0L = Battery 340 A (70 Ah)
D93 = 4-cyl. turbo dies. eng. 2.0 l/125 kW 4V TDI common rail Base engine is TG3/TH3/TL4/TM4/TP4/TU3
1G0 = Without spare wheel
2PP = Leather multi-function steering wheel
3FE = Electric slide/tilt sunroof with sun screen/sunblind
8AY = Radio/navigation system
L30 = Suspension range 30 installation control only, no requirement forecast
G15 = Front shock absorption
Passat VI Dsg 170 Carat.
Aller ont réveille le décodeur pour des question...
Perso je connais pas du tout ce logiciel.
Ou trouve t'on ces 3 lettres chiffres ???
L'étiquette se situe dans le coffre ou sur les côtés.
Ok sa marche je verai sa demain...
En fait ont rentre ce code sur le décodeur et sa nous dis les options ou pas du véhicule ?!?!
Oui séparé par un point virgule.
Je suis aller voir si je trouve ce code dans le coffre, mais un peut con je ne sait pas ou chercher cette étiquette.
Elle ce trouve ou ? a gauche a droite derrière une moquette, coter roue de secours ?
Dans le bac de la roue de secours ou dans le carnet d'entretien de ta Passat. wink
Merci...
Alors là je pleure de ne pas l'avoir lu avant ,ça m'aurait évité bien des déboires avec ma rotule inférieure avant sad  mais grace à ça je ne ferai pas la même erreur pour les amortisseurs :cool .un grand merci pour le partage
suis nouveau sur le site et je voudrais savoir a quoi sert decodeur codes options car je viens d'acheter une passat sw 2l 140 confortline
fred
http://s29.postimg.org/pngizxj8j/20140131_115603_1.jpg
Fred
Cela te sert à décrypter ta carte code wink
http://igorweb.org/equidec/howto.html Voici comment réaliser l'opération.
ok merci mais c'est a dire car suis plus que novice dans le domaine
Fred
ben ca te donne les options de ton véhicule et de quoi il est composé frederichenry.
Roule Bas ou roule Pas
Ma présentation ICI http://www.forumpassat.fr/forum/topic/2 … line-2006/
Polo 6n 1995 1.3I, Polo 6n2 2001 DI 102 cv, Passat 2006 1.9 TDI 105 cv.
CN8 = Alloy wheels 7J x 16
G0C = 5-speed manual transmission
HJ7 = Tires 215/55 R16 97W x1
D3W = 4-cyl. turbo diesel engine 1.9 L/77 kW TDI with pump-jet injection system Base engine is T71/TG0/TD0/T5X
1G2 = Steel spare wheel with original equipment tires
T71 = 4-cylinder diesel engine 1.9 L unit 03G.1
3S2 = Black roof rails
1LJ = Disc brakes, front
0GG = Emission standard EU4
J'ai une question, qui pourrait me traduire ou m'expliquer exactement à quoi correspondent les deux options suivantes ???
0YK = Weight range 10 installation control only, no requirement forecast
Merci d'avance.
Pour déterminer l'équipement, les éventuels options, sur l'étiquette du véhicule le réparateur y troupe les PR codes
Si tu as un gros choc avant qui nécessite l’échange d'un amortisseur et d'un ressort, le magasinier te commandera un amortisseur de rang 30 (L30 ) et un ressort de charge (OYK) par exemple.
