Sujet : [Passat V] Notice VW montage régulateur
J'ai numérisé la notice de montage du régulateur pour 3B/3BG essence et diesel
Comptez une demi journée pour le montage si jamais fait.
Voila :
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13512213_10154317195229106_26585557286790549_n.jpg?oh=18a72c03ac5e6347348c547de0ba0745&oe=580537AD
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13592654_10154317195324106_3330093205996250830_n.jpg?oh=0871608727291919511064b9459e27a2&oe=57FDAAC1
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13606593_10154317195374106_3832635786251267531_n.jpg?oh=95219cd4c3431e2a8939f1e99fbc7afb&oe=57F5B0C3
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13599885_10154317195414106_5292705381573704886_n.jpg?oh=6c393090b338a55819ed0a594b3d9b78&oe=57F19025
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13600021_10154317195484106_6975581128636257837_n.jpg?oh=4c00135a9dd9e283e9e39e709a6e3851&oe=58038409
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13600174_10154317195529106_1056907916646844567_n.jpg?oh=8e47003eb08d8da02fb89b6fad7b20dd&oe=58029262
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13592701_10154317195574106_1450350606221924719_n.jpg?oh=78b6c8a06c86a6e6ed3f3cc95c48cc04&oe=5801FEE9
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13592576_10154317195619106_4180686201558227551_n.jpg?oh=7aa44c01cd517e571f87c8cc4001e3d4&oe=57FE6EAD
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13533208_10154317195649106_7428171590915403319_n.jpg?oh=f4049e3acce67950da5718886a626c8a&oe=583160E1
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13590320_10154317195759106_3149715293242735564_n.jpg?oh=ce59f2c7944f9f8e12dd23d75af6fee4&oe=5802C713
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13592432_10154317195809106_4275274786062054891_n.jpg?oh=2f5649cae05116c9cee2ffb4413f205f&oe=57F501FA
https://scontent-cdg2-1.xx.fbcdn.net/v/t1.0-9/13438874_10154317195869106_4140440829918659558_n.jpg?oh=e155855a0117f870c7d5fc718721b790&oe=57EB05F7
Re : [Passat V] Notice VW montage régulateur
Merci pour le guide pierre beau travail.
J'avais une simple question .
Le mien fonctionne par intermittence. a coté de sa j'ai mon bouton warning qui fait des tic tic tout seul et quand je bouge le commodo sois sa va plus vite sois les tic tic s'arrete. je pense que le fait que sa tic tic et que mon regulateur fonctionne par intermittence est lié.
Je veux donc simplement changé mon commodo. pour cela suffit juste de le debrancher et de rebrancher un autre c'est sa ?
Salut merci pour tout ça ! Je voulais savoir un truc , sur la 1ère page , il y a 2 références de régulateur , c'est quoi la différence ? Et tu la déjà monter ? C'est asser faisable ?
Merci wink
Bonne question pour les références... smile
Je pense Essence et Diesel, mais pas sur.
Suffit d'acheter avec la CG chez ton concessionnaire préféré ! tongue
Je l'ai installé sur plusieurs passat TDI, et golf 4, c'est faisable, mais faut prendre son temps pour pas faire de bêtises. Maintenant que j'en ai fait plusieurs, je mets 3h environ.
Oui, c'est en fonction de l’énergie utilisée, essence ou Diesel.
Ca se trouve assez facilement aussi sur la baie...
Oui pour ebay. mais attention tous les faisceaux ebay n'ont pas les même couleurs que la notice d'origine.
Il m'a fallu reprendre la RTA pour faire la correspondance avant de le monter pour ma part.
Merci pour vos réponses , je pense que d'ici cet hiver je vais faire plaisir à ma cheville sur mes longs trajets x)
J'ai tenté d'acheter un régulateur chinois sur aliexpress. Le faisceau n'a rien à voir au niveau couleur et pins, j'ai donc essayé de me repiquer avec des cosses sans coupure sur les fils mais que neni ça ne fonctionne pas ...
Quand je vais dans moteur, grpe de mesure, canal 6, je regarde un peu si mon commodo réagis (au niveau des bits) et il ne détecte pas la mise en route, il détecte juste l'appui du bouton SET.
J'ai refait encore le faisceau mais rien n'y fait, j'arrive pas à le faire marcher le salop. Je vais acheter un original sur ebay pour un prix 8 fois plus cher tant pis.
Si quelqu'un a un régulateur ali et qu'il marche j'aimerais bien savoir !!
Iso
Mon Panzer : Passat 3B année 2000, Basis, TDI 90 AHH boite EAB : ESP, MCD, Centralisation 2nde monte, Radar de recul 2nde monte, FIS Plus, attelage, EGR OFF (plaque), 5W40 Castrol Edge, Hankook Kinergy Eco 195/65R15 : 160 000km Conso 5l/100km
Tu a le lien?tu as bien cablé?
Difficile d'être sur à 100% de mon cablage car un peu cablé comme j'ai pu... Mais j'ai revérifié aujourd'hui (j'ai cablé il y a 3 mois) et c'est tout OK ... Le cable du ON/OFF je ne sais pas le quel c'est, j'aimerais être sur que ca vienne du comodo ou que du cablage mais je ne sais pas comment faire
voici le lien : https://fr.aliexpress.com/item/VOLKSWAG … 55160.html
Iso
Le câblage golf 4 est différent de celui des Passat il me semble. sad
Oui le cablage est différent d'après les tuto, mais le comodo c'est le même ? Si je rachete juste le cablage et que je garde mon comodo tu pense que ca peut le faire ? Je sens que je vais tout racheter en origine comme ça je refait mon cablage proprement et j'augmente mes chances de le faire fonctionner comme il faut.
Iso
Colodo identique
Prend un câblage sur eBay.
Attention à ce que ce soit bien  un faisceau avec le bouton set/reste et pas à commande au volant
Quitte a avoir un faisceau a racheter je vais tenter de brancher des interrupteur pour tester au vag com si c'est mon branchement ou mon comodo qui est naze.
Iso
15 Dernière modification par pitou30 (03/10/2016 11:56:44)
Le mieux, c'est de câbler comme a l'origine :
Merci pitou, mon cablage est bon, mais je ne sais pas si ca viens du connecteur qui vient se mettre dans le comodo ou le comodo lui même qui n'est pas bon. J'ai testé au vag en faisant contact entre les fils suivant schema et tout fonctionne. Je tenterais bien de changer le faisceaux suite conseil de Tell, et si ça ne marche pas le comodo ...
Iso
Un comodo d'occaz c'est 25/30€ smile
Si ça fonctionne directement sur la prise, c'est que le câblage est bon.
Par contre, est ce que ton câblage est bon par rapport au commodo ?
J'avais vérifié les PIN à l'époque mais je n'en suis plus certain ... Je vais commander ce faisceau :
http://www.ebay.fr/itm/VW-Passat-B5-3B- … SwLnlWnsZn
En espérant que le commodo soit bon !
Iso
C'est le bon câble
http://www.passatplus.de/umbauteile/sch … alter4.htm
